Bought a pair of used 2012-2013 HID AFS headlight off ebay and a couple of D2s CBI xenarc bulbs and ballasts. Install took about 2 hours. Rewiring was a breeze. I was shocked. After months of checking this board I didnt get any decent info of how hard it would be to adapt the wiring harness. It was a piece of cake. 10 minutes tops per side. You just have to remove the old harness, remove the new one entirely and splice the old one according to what wire went where....It was simple. The headlight adjustment even works!!! The only mod I had to do was adapt the D2S bulb to the D4S housing. (2 minutes with a soldering iron to melt a small notch in the plastic.) The lighting is beautiful and a huge improvement over the DIY projectors I had before. Now I just have to figure out how to manually adjust the lights up a bit because they are a little low. (my lift probably put the factory level outta whack.) One thing to nit pick: the stock leds could be a bit brighter and bluer to match the color of the light bar and xenon bulbs.
I highly recommend this mod.
