- Thread starter
- #21
ats4x4dotcom said:...they transform the ride of the 100 IFS cruiser/lexus for on and off road, loaded or unloaded, with the velocity controlled valving we use for our own shocks.
What about the stock Bilsteins on the 80?
fzj80kidpen said:I am currently running stock.
Just added OME 2.5" springs.
Keeping the monroe stock shocks.
This is the way I understand it.
Better over all ride go to new springs.
Softer shock - OEM
firmer shock - OME
Firmest shock - Bilsteins.
Pick your poison.
If you bouncing then just replace the shocks OEM.
If you have a heavier load, springs and shocks.
ductape said:by low lift springs, what do you mean, 2.5 in OME med? with bilsteins B46-1477/78? or a different model?
kixtand said:The quality issue w/ OME seems to be a recurring theme. Bilsteins, however, are consistently regarded as very high quality and durable. That fact alone may make the decision to go w/ Bilsteins for me.
cary said:The 861/862 <1" lift. Remember cruiser is both underdampened and undersprung, so upgrading both shocks and springs is the best alternative.
Arsenal said:im putting on some bilsteins this weekend also, 10 inch travel with man-a-fre's stud to eye adapters. will report with my findings
Arsenal said:i believe the part number is be5-a464-h5 25.93 ext. 15.11 col. 10.82 in. travel . got 4 for like 280 shipped. i am installing them saturday with the man-a-fre 5/8" eye adapters.
fzj80kidpen said:Cary,
Thank you clearing up a misconception on Bilsteins I seem to have picked up reading all these threads. It sounds like to are impressed with the Bilstein valve setup. What do you know about the difference between OME and Monroe shocks? They seem the same to me.
cary said:The only change I would make to the valving of the OEM replacement bilsteins would be to add a bit more dampining to the rebound side of the rear shocks. That said, I tend to like a slightly overdampened rear shock.
Darwood said:I'm interested to know how this goes. According to the Bilstein sight these shocks have 170/60 valving. I would have thought to go for the BE5-6248-H5 which has a valving of 255/70. Of course I want a firmer ride than I currently have, especially with the compression dampening.
Darwood said:Also do you happen to know the lengths? I could probably search for the latter, but I'm feeling lazy.![]()
RavenTai said:...if you are not sure if you are ever going to lift or may go with a low lift and are looking for cushy shocks the OEM LC shocks from Dan are the best bang for the buck, about $100 for all 4,
LandCruiserPhil said:FWIW According to Bilstein shocks with 170/60 valving is for dual shock setups and too light for a Land Cruiser used alone.
