Any issues with using OEM shackles / U-Bolts with OME springs. Don't want to spend an extra $200 on shackles / u-bolts for something that isn't necessary.
Thanks. That’s a good place for me to start. The truck runs great with no vibrations so will measure and match shackle length.if it runs well right now with no vibrations i’d try to find a shackle of the same length. otherwise you may change your pinion angle which leads to needing castor shims etc which work but are a bit of a pain to sort out.
Thanks @cruisermatt appreciate the confirmation on my set up. Do you list the 4 degree shims, shackles and Japanese Ubolts on your site?
Also, with the OME 2.5” springs, is 4 degree the standard? I have not measured the pinion angle yet to confirm….If you know this is the right correction it will save me some time.
My ubolt plates are in good shape front and rear but those new ones are tempting me…
