- Joined
- Feb 10, 2002
- Threads
- 550
- Messages
- 44,777
- Location
- Canton, Mississippi
- Website
- www.seeandeatms.com
Two showings in the top 9 son
What size spacer do you need to run? Wondering if the 16" rims would clear everything since the b.s. is 4.25Also got the wheel and tire situation sorted out....big thanks to, you guessed it!..... @wct49 for getting my tires and wheels mounted and balanced up....as well a set of spidertrax spacers.....needed them to clear the steering/tie rod joint on the passenger side. i tried to run without them, but it wasn’t in the cards as the steering joint would rub the passenger side wheel when turned to the left......
[the wheels are fifteen52 analog 17x8.5” with 0 offset / 4.75” BS tires are TOYO open country M/T 285/75 - 17 load range E in case anyone was wondering....they fill in the fender wells nicely, and will look even better when that weight gets put out back with the bumper]
i am liking the ride of the iron man lift. The springs have settled a bit and are not too bad even with no weight in the rear. It’s still sitting up a bit and is ”bouncy”, but should settle when the Four Plus bumper and sliders get installed.
View attachment 2423974View attachment 2423975View attachment 2423976View attachment 2423977
Quick vid of the cutter in action:
This Big Boi bruiser is probably back at base by now, but it left the Summer Ave alien workshop this afternoon.
We squeezed in all the woopow. All of it.
It’s either going to be badass or blow up before it even cranks from woopow overdose. Can’t wait to find out.
