Oil Vs. Grease?
As often times happens, curiosity has gotten the better of me. So why does Toyota choose grease to lubricate the CV joints in the front axle knuckles instead of oil? There seems to be so many problems with the front axle seals failing, and the axle gear oil leaking into the knuckles and washing the grease from the CV bells. Just made me begin to wonder why the choice of grease over oil? Is a good EP Grease really a better lubricant for the CV joint, or was Toyota more concerned about the knuckle seals leaking oil and leaving the joint dry? Did Toyota ever use Oil, maybe in earlier Land Cruisers? (I’ve been educating myself about the 80 Series and 100 Series Cruisers, but honestly don’t know that much about the earlier models) And if so, why the switch to grease.
I know Land Rover used oil in there closed knuckle CVs for 40+ years, and issued a service bulletin to switch over to a “One Time” grease when trucks where brought in for service pertaining to leaky knuckle seals. Personally I think Rover did it to save labor costs for warrantee work, since it is an involved job to disassemble everything to replace the seal, not because of problems with the oil properly lubricating the CV joint.
