Hi, I decided to start anohter thread as my topic has expanded. My truck is the one that is pinging on high test and I just changed out the VSV (already changed out the EGR and the modulator). The CEL is out how so so that is good. My pinging has improved about 90% but is not totally gone.
During the change out of the VSV, I also changed the PCV valve. When I did this I was shocked by slude on the valve and around the hole in the valve cover. I stuck my finder in the whole and pulled out some of this black glop. Is this a common problem and should I be concerned? My mechanic replaced the valve cover gasket a few months ago due to a leak and he did not mention anything about the sludge. Could this be from my EGR problem that is the system not working properly?
My truck is in very good condition and has 77k on it. The body is flawless and the interior is great also. I have only had the truck about 9 months and have spend a small fortune on repairs. Is this a real serious problem?
Thanks
Andrew
Thanks
Andrew
