With the engine at operating temperature and turned
off, check the oil level on the dipstick.
1. To get a true reading, the vehicle should be on a level
spot. After turning off the engine, wait a few minutes for the
oil to drain back into the bottom of the engine.
2. Pull out the dipstick, and wipe it clean with a rag.
3. Reinsert the dipstick and push it in as far as it will go, or
the reading will not be correct.
Add oil O.K. Too full
4. Pull the dipstick out and look at the oil level on the end.
If it is between the full line ( ) and the low line ( ), it is O.K.
If the oil level is below or only slightly above the low
line, add engine oil of the same type as already in the
engine.
Remove the oil filler cap and add engine oil a little at a time,
checking the dipstick. The approximate quantity of oil
needed to fill between the low line and the full line on the
dipstick is indicated below for reference.
When the level reaches within the correct range, return the
filler cap and turn the cap clockwise until you hear a click. [....RT, what click? my cap is solid)
Oil quantity. L (qt., Imp. qt.) 1.5 (1.6, 1.3)
