Just completed long trip (11,000km) in 1976 fj55 with 2f motor.
To my dismay on return we found some oil in the air cleaner housing above the carb. Have since noticed two of my sparkplugs are fouled (white and crusty). Have given the beast a full service including a new manifold gasket as the new headers where leaking from a blown gasket. Is running beautifully not blowing smoke and not using much oil that i have observed. Oil pressure gauge reads high (off the scale) and have a reasonable leak below the pcv valve which i renewed recently -also i found the exhast tappets had become tight over the trip, i run 98octane premium unleaded with upper cylinder lubricant, I had hoped this would keep everything running free.
Any thoughts, is it blow by? burnt valve? I have no cylinder pressure tester, but i guess that would tell me whats going on.
I am thinking of putting some kind of canister on the top breather hose off the rocker cover, to collect the oil. Have allready tried retro fitting the old pcv valve (which still rattles) into the top hose, but the pressure build up blew off my oil filler cap...! which im still looking for
Cheers for any help you can give.
