I ran a compression check 175 to 183 on all cylinders. I've been reading FSM this afternoon thinking there was something obvious that I missed.....Then the wife walked by and said Would it be that little box the previous owner had on there? She may have something there. PO had put some type of computer kit on the MAF sensor. I've taken it off before and it ran terrible with out it. Now I'm thinking that I didn't give the old computer long enough to learn how to run without it.
It would almost make sense that if that computer mounted on the MAF caused smaller valve opening you would have greater velocities on the air flow through there. Big Venturi as well as made up air needed out of crank case. Looks good on paper but I know that I may be all wet here. I'll clean up the MAF and take off the computer thingy and slap her back together.
PS. I noticed that I have oil on the upstream side of my MAF. Whole big rubber tube has oil in it. I either have entirely too much crancase pressure or entirely too much flow from my crancase ventilation. I was kind of hoping one of you guys had seen this before and would say......Look here boy....This is what is going on!!!
