Guys,
I replaced my valve cover gasket a couple of weeks ago, and completed a few other PM items while I was at it. Since then, I have had some rough idle issues and decided to replace the air intake tube to make sure that wasn't the issue. When I took the old air intake tube off, I found some motor oil pooled on the bottom of the throttle body. I replaced the pcv and hose while I was doing the gasket and also replaced the other hose on the top of the valve cover (I think it is some sort of breather that leads to the throttle body). Can someone please let me know how to fix this? I am guessing this has something to do with my idle issue, but I have no idea what is causing it, or how to fix it. Thanks in advance, guys.
You add the catch can between the PCV filter on the valve cover and where it enters the throttle body. I have mine mounted on my battery tray. I'll post a picture.
