Newbie question... Planning on first oil change on my 03 LX470. Looks like the oil filter access is from under the vehicle, will removing the filter first cause spill? Do you guys drain the oil before replacing the filter?
(Edit)In addition to an answer to my question, I got a nice oil change 101 from this post.
Oil Change 101:
1. Warm engine before oil change
2. Remove oil filler cap
3. Put your catch pan under the drain plug
4. Remove oil pan drain plug and let all oil drain out until you have a very slow drip.
5. Replace drain plug using new plug gasket. Torque to spec. Wipe clean.
6. Move catch pan under oil filter
6b. (100 specific) Punch a hole at the bottom (well really the top) of the filter to drain then remove
7. Remove oil filter and pour contents into catch pan.
8. Make sure the old gasket came off with the old filter, and wipe off surface where the gasket seats. Lube new oil filter gasket with a thin coat of new oil. Install new oil filter. Tighten as much as possible by hand. No wrenches.
9. Pour in new oil. Check oil level.
10. Start engine, check for leaks at the drain plug and filter.
11. Shut off engine, wait 15 minutes or so and check oil level. Add more oil if necessary, until proper level is indicated on the dip stick.
Oil Change 101:
