Official ONSC member buying/selling thread (55 Viewers)
That was my fallback position, too. Although, I'm tempted to remove the bracket from the bellhousing and let it go.
Damn. I think I know the part you are looking for. I threw it away just a few months ago when I installed an aftermarket exhaust.
Thanks anyway. The OEM clamp ring is about 5-mm thick, and mine is down to 1.5-mm. I don't know where this truck came from to get that much rust on it. The frame and body are spotless; it's just the exhaust that's eaten though. I'll have to post a picture - the O2 sensor nuts are gone. Not the sensor or flange, just the nuts. I've never seen anything like it.
Pretty common for the O2 sensor nuts to rust away and the studs still be completely intact.
That was a new one for me
FREE! Free furniture posts allowed? Two large pieces - cabinet and matching coffee table. I think rosewood? Both heavy. Cabinet has cast metal door inlays and hinges. Table has drawer. The catch - will need help moving from storage in SouthPark area.
Calling all parts hoarders:
I need one (1) clamp ring for a 1995-1997 80 series Y-pipe to the bellhousing bracket. Mine has dissolved due to iron worms.
LMK
I have an aftermarket SS clamp I bought for that purpose but did not install before the grand oops. Sourced per mud recommendation for that exact application
Evil energy exhausts
X001scs737
That might work...the OEM clamp has a flat(-ish) spot on it to mate with the bellhousing bracket, but as thin as is it, it could probably be made to work. I as surprised when I measured the one one my truck - it's almost 4-mm thick. The iron worms ate 3/4s of the old one away.
I'm looking for a Slee or Dobinson's 6" lift for my 80. Mainly the springs and shocks. The Slee Front Control Arms would be a massive plus too. Same with the Slee/ADS shocks. I thought that I would put wanted to post up to try and save some money. Thank you.
FREE- Kelty kids, back country baby backpack for taking a baby on a hike, also a Britax car seat, and a seat for a bicycle that removes from the rack mount.
Great, plan to have some kids in your future? Mind you these are old but I inspected them and believe they are still in good working order. No brittle straps or such.
No plans. But a good friend had his first today.
I’d like to clarify I would just like to get the backpack carrier. The others should
Remain available for others.
Thanks.
Thanks.
I also have a changing table in the attic
Pictures of new Dinitrol 977 and 958 two-stage undercoating after surface rust removal and detail cleaning by Merritt Motor Co in Kannapolis! Next up, I plan to address the small rust spot under the door handle that was noted in the listing thread. After that, I'll get the interior detailed and it will go up on BaT!
OK, I'll bite. How much did that cost?
Free…. Pair of OME 861 springs hardly used, still shiny
