That was my fallback position, too. Although, I'm tempted to remove the bracket from the bellhousing and let it go.
Thanks anyway. The OEM clamp ring is about 5-mm thick, and mine is down to 1.5-mm. I don't know where this truck came from to get that much rust on it. The frame and body are spotless; it's just the exhaust that's eaten though. I'll have to post a picture - the O2 sensor nuts are gone. Not the sensor or flange, just the nuts. I've never seen anything like it.Damn. I think I know the part you are looking for. I threw it away just a few months ago when I installed an aftermarket exhaust.
Pretty common for the O2 sensor nuts to rust away and the studs still be completely intact.Thanks anyway. The OEM clamp ring is about 5-mm thick, and mine is down to 1.5-mm. I don't know where this truck came from to get that much rust on it. The frame and body are spotless; it's just the exhaust that's eaten though. I'll have to post a picture - the O2 sensor nuts are gone. Not the sensor or flange, just the nuts. I've never seen anything like it.
I have an aftermarket SS clamp I bought for that purpose but did not install before the grand oops. Sourced per mud recommendation for that exact applicationCalling all parts hoarders:
I need one (1) clamp ring for a 1995-1997 80 series Y-pipe to the bellhousing bracket. Mine has dissolved due to iron worms.
LMK
^^^^^^^^^^^ @Hokie LXSelling my tow dolly. Rated for 6000 pounds. Has trailer brakes and straps. New tires, new led lights, new 7 pin plug. Has removable ramps. 82" between fenders. Easy to store. View attachment 3931435View attachment 3931432View attachment 39314361800.00
I’d rather have a trailer than a dolly for my needs.^^^^^^^^^^^ @Hokie LX
ClaimedFREE- Kelty kids, back country baby backpack for taking a baby on a hike, also a Britax car seat, and a seat for a bicycle that removes from the rack mount.
No plans. But a good friend had his first today.Great, plan to have some kids in your future? Mind you these are old but I inspected them and believe they are still in good working order. No brittle straps or such.
I also have a changing table in the atticNo plans. But a good friend had his first today.
I’d like to clarify I would just like to get the backpack carrier. The others should
Remain available for others.
Thanks.
OK, I'll bite. How much did that cost?Pictures of new Dinitrol 977 and 958 two-stage undercoating after surface rust removal and detail cleaning by Merritt Motor Co in Kannapolis! Next up, I plan to address the small rust spot under the door handle that was noted in the listing thread. After that, I'll get the interior detailed and it will go up on BaT!
