Official ONSC member buying/selling thread (8 Viewers)
I got a drivers seat tool box cover that is in good shape with some surface rust if anyone wants it. I can ship this thing as it is not too big / heavy.
What kind of tool box cover? Do you have a picture? Do you think it will fit under my '77 driver's seat?
I doubt it, but I am intersted if you think it might.
Its also for an older model 40. You would have to fab up an entire other part for your truck.
285/75R16 BFG ATs
Set of (4) 285/75R16 BFG AT KOs for sale. Two of the tires are like new, two are around 50% tread. $500 obo Located in Roxboro.
R.K.
Might have a smog pump for you Erik. I'll call tonight.
Going to be parting out a '78 FJ40 and a some stuff from a '74 real soon. Anyone in the market for a 4" BDS lift kit?
Hey I need some parts so let me know when you do, In particular a passenger side fender,and some others,
Thanks.
Everyone, I probably should not have posted yet, but I wanted to see what kind of market there will be for parts before I take on this venture. IF and WHEN it happens, (likely within a couple of weeks) I will start posting more details. In the meantime, I want to see if there is any real interest in a couple of the "bigger" items. I will sell everything on a first come, first served basis assuming the buyer gets me money in hand in a reasonable timeframe.
Rolling Chassis from '78
This is the description I got from the PO:
1978 FJ40, titled and registered in North Carolina.
She was running when I bought her, the 4-wheel drive worked, so the drive train seemed pretty functional. The tub and rear cross member had severe rust and rot and the interior was pretty much trashed. I’ll try to be as accurate as to the condition, and what I recollect I sold or was missing, but it’s been two years since I’ve touched it.
Frame, axles, transmission, transfer case, and motor, all functioned prior to teardown. With the exception of replacing the rear cross member and spring hangers (steel-fab reproductions) the chassis is rolling and has not been touched. The frame and all components are in really good shape, with little or no rust.
4" BDS Lift Kit
I've got 2 people "in line" so far that have expressed interest.
1 dash / cowl, stripped and in good shape
All heating, box, tubes, ext, no rear heater
Now's the time to get "in line" if you think you will be interested in any of this stuff. Prices are not set yet, but will be very reasonable and based on current market pricing for similar items sold on MUDD. I'm trying to keep most of the stuff local pickup to avoid the headache of shipping, so that's why it's going to be listed here way before I head to the MUDD forsale forum.
Thanks,
Ramon Weller
FJ40 parts for sale
Hi all, I need to clear some garage space and free up some cash flow so I have some FJ40 parts for sale, not sure what model they came off of. I picked them up to fix my 40 when I got it. I can send pics if needed.
Fenders L & R with late model turn signals attached (some rust in the lower section near the running boards but very solid) : $100
Drivers side fender apron (some surface rust) : $25
Rear half doors L&R with hinges (no rust, latch has some wear): $200
1979 FJ40 parts:
Mirror assemblies and mirror heads (heads have some cracking in the plastic but still usable) $40
Rear drum brake assemblies from a 79: Make offer
Np205
Chevy NP205 t-case, was mated to an SM465. Passenger output front, center output rear. Nice tight case. $150
R.K.
Built F&R FJ40 axles FS - bolt-on spring over!
https://forum.ih8mud.com/showthread.php?t=123635
FJ40 front axle.
set up for spring over
knuckles have been cut/turned 16 deg
armored removable front diff cover
4.10 gearing with LockRight locker
4340 cromo inner shafts and birfields
All-Pro spindle stud kit
Minitruck knuckles
High steer
FJ60 calipers and rotors
braided brake lines (Crown)(Does away with the backing plates)
Aisin hubs
U-bolts and plates included.
Axle has been recently (1 year ago, less than 12 trips since) rebuilt. $1000
FJ40 rear axle.
Set up for spring-over
4.10 gearing
has disc brakes
stainless braided brake lines
comes with spare axle shafts. $500
Also some spare parts like 1 aisin hub($50), 2 warn hubs ($35), 4.10 third member ($125)
