Built FJ40 axles & tranny/t-case in NC
Roxboro, NC
FJ40 rear axle for sale. Set up for spring-over, 4.10 gearing, has disc brakes, stainless braided brake lines, and comes with spare axle shafts. $500
SM465 tranny mated to FJ40 t-case with aluminum adapter plate. Tranny has recent rebuild. Tranny has input collar to be mounted behind FJ40 straight 6 engine. Transfer case is twin sticked, has t-case saver installed, and has AA cross member. The 3-speed bellhousing is included to allow this unit to be mounted to a Cruiser engine. Will also include the .120" wall tube rear driveshaft from the set-up (is long enough for spring over with flipped rear springs). $700
FJ40 front axle. Axle is set up for spring over, knuckles have been cut/turned 16 deg, has armored removable front diff cover, 4.10 gearing with LockRight locker, 4340 cromo inner shafts and birfields, All-Pro spindle stud kit, minitruck knuckles, high steer, FJ60 calipers and rotors, Aisin hubs, U-bolts and plates included. Axle has been recently rebuilt. $1000
The rear axle and tranny/t-case are located in Roxboro, NC and the front axle is in Holly Springs, NC (near Raleigh). No shipping. Buy both axles and you'll have a bolt-on spring over.
R.K.
RK - What're you building up now? Let me know if you end up parting I'd be interested in a tight fine spline 4:10.
He's keeping Toy axles, but now running my old centered cruiser rear to better go with his :grinpimp: new driveline...
Looking for a fine spline front diff, but his might be too thrashed :D to be reliable enough for me.
If you part - I'd be interested in the spindle studs - maybe the whole knuckles as I can't see pulling just the studs? Same steering arm bolt pattern as FJ60 correct? What studs are in place for the steering arms...
Might consider parting the front axle.. interest?
I'd want to sell the whole knuckle, but preferrably the whole knucle out for someone upgrading from drums..
Yeah, FJ60/minitruck/late FJ40 knuckles, all the same.. stock studs. I check the torque daily, and have NEVER broken a stud, nor has anyone who started torquing them regularly.. :)
wish I could afford both front and rear axles w/disc brakes....thinking about converting my drum brakes (67FJ40) to disc brakes...
This is just a sik deal - surprised no-one has gone for it yet... Saw R.K.'s 40 at the top of the chute on Schoolbus last week - looking good.
If you end up parting, I'd be interested in the rear drive shaft if it's a double carden, the twin stik if I can use it on a similar setup but where I use the AA 4.5" adapter, and maybe one or both of the Asins for spares. I've got most everything else so far...
Good luck - anyone considering building up a wheeler should jump on this package - it's a steal!
dang...my loss....R.K., do u know anyone who may b selling front/rear axles w/disc brakes???...thanks..
