Hey Guys and Gals -
My 40 has been badly neglected over the last couple years and now I find myself having to pass smog in order to register it in Kalifornia.
To start, I have a '76 with a '79 engine. It is set up with the dizzy/igniter from the '76 (vacuum retard) and just about all of the stock smog goodies intact.
Before taking it for the smog test, I changed the oil (10-40) and filter (Napa Gold 1773), replaced the spark plugs (NGK BPR5EY-11) and plug wires, put in a new air filter and dumped a quart of denatured alcohol into a tank full of premium gas.
The old plugs don't look awful, but may have some evidence of burned oil on them. I get some smoke out the tailpipe at times, too, when it sits for a while.
Anyway, at the test I maxed out the machine on HC....over 2000!
The CO was at 3.19 (which should be around 1.80).
I came home and adjusted the valves (which hadn't been done in a LONG time) and took it back. Still no good. Came back home and did the following:
1) Checked that the smog pump is working
2) Did the lean-drop method of idle adjustment on the carb
3) Verified that the idle solenoid was "clicking" when key turned (though weakly, it seemed)
4) Checked vacuum at the intake (brake booster hose). Had 24" with a bit of a flicker (I'm at about 4000' elevation)
5) Checked the dizzy alignment. Don't have a timing light (yet) so just adjusted by ear.
I'll take it back tomorrow to see if I've made any headway, but I'm thinking with super high HC like this, I'm probably looking at burned valves or.....
Depending on what happens tomorrow, I'll do a compression check and start from there.
Any other tips, advice or opinions out there? Thanks in advance....
