I've started my subtank install and just wanted to document some of my failures so far so others might not have to deal with my issues:
1. Rivnuts
Cyclosteve and I, installed the most rear rivenuts. No issues really just watch your eyes for falling hot razor sharp metal that comes from drilling these holes. For the forward most rivnuts, we actually just drilled holes and went through the cross member. Good luck getting rivnuts in there. I'm sure it's possible but it would be a complete pain. Drilling and using bolts worked well.
2. Tank straps.
They are marked with a R and an L. Make sure you put them on the correct side. They are a different length and shape. I put mine on the wrong side and now I need to wait until I get someone to help hold a wrench while I take out the nut!
3. George's ECU
When I turn my switch around and look at the back of it, it doesn't look like this
Go to the switch and ECU diagram: http://web.archive.org/web/20101230184545/http://www.bajaoverland.com/auxtankinstall.php
My switch has pins 5-10 on top and 1-4 on the bottom. I have to flip it upside down to get this look. When I do, I'm not sure which pins are which? I just used the two upper right pins as my backlight. It's confusing to me but I have a caveman mind. I wired it all up and did a test and no lights no pump nothing. I'll try it again soon after I relax for a bit. Pictures to follow.
I'll post up where I got my fill tube and fittings shortly. Also, I went with a NAPA pump.
1. Rivnuts
2. Tank straps.
3. George's ECU
