@masface I've been meaning to PM you back! Just been too busy this weekend, sorry!
It's been a while since I pulled my codes, but it could be you do have a 2 and an 8 code. One is the boost sensor, which would match the issues you are having. It's mounted against the inside fender on the passenger side of the vehicle. The boost lines from the intake manifold run to it. Just check that it's plugged in and the wires are not damaged at all. And you already checked your boost lines to make sure they are in good shape and did not pop off right?
Can you look at the part number on the boost sensor. I do actually have a spare one that I could potentially send to you to try out. Are you in the US or Canada? Where?
As far as the air temp sensor goes, that is by the air filter box. Plugs into the air intake hose there I think? Just check that it's plugged in ok. You might need to reset the codes also to see if they go away as you change stuff.
