For Sale NW MT PTO winch setup
nw montana
Off 69 Fj55 been in barn maybe 15 years. Not willing to ship unless still have this fall $1200
let me know if your willing to ship. I could send shipping labels and arrange pickup if you can box separately Im looking at a few other PTOs.
Missing bumper spacers?
Is 55 shaft/bearing/mount and 40 the same?
It came off solid case transfer. I disassembled and put the gear and spacers in the white box. I also have the front bumper extensions that push the front bumper forward. I’ll take a picture of them. I imagine the PTO drive shaft is similar but perhaps slightly different length to a 40. This was probably installed at the dealer as the floor board hole didn’t look factory.
If I still have in the fall. Thanks
Bumper and extensions both decent
No. Up to 1/79 the FJ40 PTO driveshaft support bearing mounted to ears on the radiator bracket. FJ55 mounted to the frame side rail. The holes thru the front crossmember on the FJ55 are offset because the short driveshaft goes thru at an angle.
no bumper spacers on a 55 winch head
the bearing is the same on the driveshaft but as stated by John above the driveshafts are different between the 55 and 40
IIRCC the frame mount on the 55 attached below or very close to the riveted frame motor mount
the front bumper still looks decent
Are you still interested? Found a 3/4”plywood crate I can modify. Looks like I would have to cut the driveshaft to fit. It already looks like it was welded
Price drop includes bumper extensions to $1000, local pickup only
