Not a build thread (2 Viewers)
I may have mentioned this but I think I got lucky with this Land Cruiser. I bought it from the original owner. It was originally purchased in Farmington, NM and lived its life in Cortez, CO (the south west corner of Colorado). Spending most of its life in a dry desert environment means it has very little rust, mostly surface rust or the rust has been well hidden (it has been repainted at some point). The one place that is rusty is the bottom of the tailgate. I'd been worried about this for some time and when I ran across
60 Series Land Cruiser tailgate storage mod - https://hfabusa.com/products/60-series-land-cruiser-tailgate-storage-mod?srsltid=AfmBOoodEqVWbxtiLuSM6VtXMyXkAR88Iij8IRw6JFjRDmhfxYVjnsz3
I figured if I'm going to try to fix the rust that I might as well cut a huge hole in the tailgate so that I can see the extent of the problem and have the best chance of fixing it.
I didn't take a good before pic but here is one after I started working on it.
I started by cutting a giant hole in the tailgate.
It actually looked better than I expected, the rust isn't too bad.
With a combination of pliers (the fencing pliers worked the best) I unfolded as much of the seam as I could.
After a little wire wheel and POR 15 rust converter it started to look better.
I applied a few coats of POR 15 before folding the seam over.
Added a little seam sealer and this little vice did a nice job of folding the seam back over.
Hit it with a little touch-up paint.
Knowing that the new touch-up paint wouldn't blend well with the faded tailgate and that my "body work" isn't perfect and any glossy paint would make it look even worse. I opted for some spray on 3M bed liner. Add a little dirt and you can hardly notice.
In August of '24 I went on one last outing into the high country with my brother before an upcoming surgery would prevent me from pushing the clutch and the snow closed the mountains.
At one point I heard that awful crack of metal braking. We determined that nothing was hanging off of the truck so I turned around and found a flat spot to assess the situation. While getting turned around I noticed that the sound was cyclical and did not occur with the clutch depressed. After jacking her up to make sure the axles would stay on, the decision was made to pull the rear drive shaft. I drove home 80 odd miles in front wheel drive with no major drama. Removing the rear diff inspection cover revealed this. I'm pretty sure that bolt aint right. This along with similar issues on the motor have led me to name the previous mechanic Over Torque.
Of course the broken bolt let to this.
And that led to call to Cruiser Teq | Land Cruiser Specialists Powered by Cruiser Outfitters - https://cruiserteq.com/ and PLC - https://www.precisionlandcruisers.com/ which resulted in this.
I am pretty sure that she does or has leaked pretty much every fluid in her. Axle rebuilds took care of axle seals, knuckles and diff leaks. Transfer case rebuild took care of its leaks. New brake and clutch master took care of those. New radiator and hoses sealed the cooling system. I have yet to address the power steering leak, possible transmission leak, timing cover, oil pan and rear main leaks but I know they're there and I'm working on getting to them. Oh almost forgot last Friday.....
Yep add fuel leak to the list :bang: I'm lucky she didn't burn to the ground. She was warming up in the morning, smelled a little gassy, pop the hood to see a drip onto the header and a puff of smoke. Killed the engine and grabbed a fire extinguisher just in case. The cover is cracked just below the top bolt. I have never touched it so I know I didn't over tighten it. And I don't think that its plastic so my superpower of breaking plastic just by looking at it shouldn't apply. On the plus side I called Holley this morning and they are sending me replacement parts. No hassle. No charge. Got to love a company that stands behind their products. Happy Thanksgiving y'all
I've been putting off pulling the door cards to investigate why the windows are so hard to roll up and down, the door lock is hard to unlock with the key, the doors don't like to open with the handles and the drivers side speaker doesn't work because I'm afraid the door cards would disintegrate on removal. Curiosity finally got the best of me....
Found more shell casings inside of the door.
I'm really starting to like finding the surprises they PO's kids left for me to find. Spliced a broken wire, "fixed" speaker.
Discovered that both door handles are broken, each have a full width crack through on one side. Ordered replacements.
The drivers window rolls up and down super smooth with the door card removed. I lubed the pivot and reinstalled the door card. It works better but not perfect. The passengers side window is a different story. I'll try to attach a video. Can this be tightened or is a new part required to fix it?
