Newbie here, got some questions
Fernley Nv.
hello all, just got a 87 fj60, #1 am wondering how much of this smog crap i can get rid of as we dont have smog laws where i live. #2 whats the biggest tire i can run with a stock fj60? #3 are there any easy, cheep lifts , such as longer shackles or something along that line?
thanks for your time.
Jim AKA NV777
Here's a couple of the threads found via archie's search...
Stock rims, stock suspension:
https://forum.ih8mud.com/showthread.php?t=92352
https://forum.ih8mud.com/showthread.php?t=73783
https://forum.ih8mud.com/showthread.php?t=62994
https://forum.ih8mud.com/showthread.php?t=50869
https://forum.ih8mud.com/showthread.php?t=87144
Stock rims, OME lift:
https://forum.ih8mud.com/showthread.php?t=35313
Lift kits:
https://forum.ih8mud.com/showthread.php?t=85356
https://forum.ih8mud.com/showthread.php?t=89640
https://forum.ih8mud.com/showthread.php?t=88947
Have no idea about smog stuff, maybe someone from NV can answer, or look for a club in your area, like the Southern Nevada Land Cruisers (hey, I'm from NC).
https://forum.ih8mud.com/forumdisplay.php?f=29
But as with all newbs, advice is "search and read, then ask". You'll get better answers that way.
desmog
You can remove a lot of the smog stuff if you are in a state that doesn't required it. I would save it if there is any chance that your state might go that way. There are some schematics in the tech section. There is a good one on welding up the EGR pipe. You will have to weld the exhaust pipe where you cut off the little pipe going in. You can remove the smog pump but you will need an idler pulley to replace it. Jim Chenoweth makes one for $100(+-). Your best bet in dealing with the desmog is to get an emissions manual. As I understand it, the carb and distributor should be set up for a de-smogged engine which Jim can do for you. I suspect that you will get better fuel efficiency when you are done and it sure makes working on you rig easier without all that stuff.
thanks
thanks all for the info. Has been great reading . Anyone close to Reno or semi close that has done the DESMOG thing hit me up. I`ll drive to you to get this done. I looked at the diagram that is posted in the tech sec. and am sure i would F everything all up if i went by that.:doh:
thanks again,
Jim
