I did mine this past weekend. Was not as bad as i expected. used a little over half of the very big blue shoptowel roles, far amount of gloves, hit the dollar store up for turkey pans, and plastic containers for sorting and cleaning. I got diesel and 5 gallons of simple green already, tried both, found simple green cleaned better but if you do that, you have to be sure to clean that off really well with brake cleaner before you start regreasing things backup. first one went slow. second one went fast. it was all the cleaning that took the most time. Prepacked the joints really well and prefilled most of the housing before installing the axel so i didn't have to work so hard to work the grease to the back with everything in the way. I had been waiting to do the front rotors and new pads until this job, so did that, and went ahead and installed new springs all the way around and did swaybar bushings. will be doing the other bushings later probably next week.
spatula from dollar store for getting the grease out and using less towels--- i really didn't get very greasy until i was sitting over the bucket cleaning the individual parts.
froze my bearing races to ease install-- was pretty easy
noticed that whoever was in there last (stealership according to paperwork) used a screwdriver to drive the bearing nuts in and out, same thing for all the cone washers etc. I guess if it was still in decent shape after all the miles after that slack job, you can probably feel really good about torquing to the right specs etc.
