Exactly what I want to know! If it's common to go out with no warning I'll replace it pro actively to avoid getting stuck in a remote area where a tow would be crazy expensive.For others that have had starter failures, do the contacts normally go bad first? That normally gives an"click, click click" but normally will start after a few tries. Is complete failure common with no warning? Maybe this should be higher on my list with 206k miles!
I think toyota would want to know what you did to make it only last 208k you must have abused itWell after 15 years in 208000 miles, it gave up the ghost.View attachment 1166803
if you have to work alone... then you might want to remove the front tires and drop the truck all the way to the ground... makes it much easier to bend over the truck a small step stool or even a chair will still help here...
Sent from my XT1060
I gave myself a week to swap it out. It was my first time ever working on the 2uzfe. I kept researching and watching as many videos as I could find throughout the week.
My first dive into the 2uzfe and I learned a whole lot. I labeled pretty much everything from bolts, nuts, hoses, connections, and took pics from every angle.
Drivers side disconnect can be a bit funky. You have fuel lines. So when you smell the fuel it makes you (me) a bit nervous.
I split the manifold apart. Lower and upper. My cousin at Toyota said that it's not a good idea to split it apart b/c of leaks. I got a new gasket. All good. He recommended unbolting the entire manifold as one piece.
View attachment 1167384now is a great time to replace the heater T's
Of course you wanna cover the ports so that you don't drop anything in there.
Getting to the bolts that hold on to the starter was a bit easier than most write. Then again I was able to jump into the engine bay and get comfy. Feet and knee placement allowed me to reach around the back, near firewall, and get to the bolts with some ease.
Do it!!!!!
Are those my pics?Drivers side disconnect can be a bit funky. You have fuel lines. So when you smell the fuel it makes you (me) a bit nervous.
Sounds like under the diff drop in front is the place to lift from?
