Hi everyone, I am the proud new owner of a 1985 fj60 as of this past weekend and I'm looking for some help with a starting issue. I purchased the truck saturday morning at which point it started up fine and I was on my way home. On my 30 minute ride back to the house I noticed a couple of things happening which I am now realizing were obvious signs something was up, however I was so pumped on my new ride I didn't pay them enough attention. After about 10 minutes on the road I noticed the battery gauge (which had been sitting roughly at the center around 12 volts) drop to the bottom of the gauge momentarily and then returned to normal. I also noticed the aftermarket head unit did not have power (I had the volume turned all the way down so I don't know exactly when it went out). There was also a faint burning smell coming from under the passenger side of the hood (at the time I attributed this to old/low coolant levels, the truck had been sitting in non op for a few years). Nothing seemed hugely alarming to me so I got home and parked it in the driveway.
Fast forward 20 minutes and I was headed out for a joyride with the family, only thing is the truck would not start. Dash lights and head unit come on, I can turn the key to the start position, I hear a click, but nothing happens under the hood. First I checked that the battery posts were clean and the terminals were tight. Then I tried jumping the car but nothing happened. Next I had AAA come by the house to test the battery and starter and both appear to be fine. Tried knocking on the starter but that did not work. The AAA guy thought it might be the ignition cylinder so I purchased a new one and replaced it but that did nothing.
This is where I need help - I am thinking the power loss is happening either at the starter solenoid or at the wire that connects the solenoid to the starter. Would that cause the momentary voltage drop I saw on my ride home? Can I test that theory without purchasing a new starter solenoid or should I just bite the bullet and order one? I've seen a few posts/videos of people installing a starter relay rather than replace the starter solenoid wire - should I do that instead? I am a novice wrencher at best but I bought this truck with the intent to learn. Well, I got my wish day one!
Any and all advice is appreciated. This forum has an amazing amount of information that I am looking forward to utilizing.
