New Ride: 67 Stout (2 Viewers)
Looking real good.
Shocks: I've become a fan of bilsteins. Maybe rig up some tail lights and drive it bed less to the muffler shop. Bet they could do a really good job with all that room.
Found my 5 gallon bucket of 90 weight in the garage and secured new diff plugs from Toyota. The diff only holds a smidge under 2 quarts, so my lifetime supply of gear oil remains.
Dropped the wheels off at Asheville Powdercoating - - an impressive operation! Tonight, I start working on the gas tank: gently remove rust, prime, and paint (I'm thinking a hand-hammered pewter color (Rustoleum), reminicent of the "Big Gay 2F")
The fuel tank project is underway. Dismantled the filler neck from the tank, only to discover that the PO had used a clear vinyl filler tube and overflow tube, rather than a fuel resistant rubber hose. Replaced at Carquest with correct new parts: $11 (sheesh, why risk something like this to save so little money?)
This is the before shot:
Plan to take everything out, clean, prime and paint compartment red.
What engine does it have? Model? Curious if I can get a carb for it.
It's the 1.9l liter that was used for the corolla and pickup up to the early 70s. I will post some pics and get the actual engine model.
Gas tank complete!
And new shocks installed ( Monroe). I went with Monroe because 1 they were on sale and 2 their website was the most helpful with actual measurements of compression/expansion as well as bushing sizes. Perfect fit. 5 minute install.
Unobtainium goods received from Cabe Toyota in San Diego. Thanks Mike Bingham!
I bet it's the 3R
And the winner is
Jay! You will receive all the PBR you can drink when you come over and help me put the bed back on. It is indeed a 3R
For Marshall
Of course it's a 5 minute install....when you don't have to crawl under the truck...jeesh
Back on all fours
Finally finished de-rustifying the underside, with only a few casualties. Need to put new boots on the ball joints, maybe replace the coil springs and radiator and hoses. You should see the lower radiator hose--- looks like someone is trying to synch a size 50 pair o Levi's around a 30 inch waist. Otherwise, the underside turned out well with no rust through. Highlight was bleeding the brakes with a hand vacuum pump, a new experience that may well have worked.
Stats: 16 cans of primer and paint; two rear shocks; 4 knotted wire wheels; 20 feet of split loom for wiring.
It's on to redoing the engine bay--- already ordered a new fuse box from the outback. Plan on taking out the components, split loom the wires, sanding down the bay, and repainting. New gaskets for valve cover and oil pan.
See you found the guy on eBay how the rims turn out
The rims are still at the blaster, and the fuse box is somewhere over the Pacific. The shipping from Au was more than the part . . .
Gutting the engine compartment
took out starter/solonoid, battery & bracket, horns so far. Gonna replace the starter with a toyota reman. Messy work, but still a bunch easier than under the truck work. Ordered a set of 10.9 zinc plated bolts, nuts, washers for good measure.
Consider this the before pic:
I'll come up whenever you are ready to put it on... I think I owe you that much. I saw you at Moe's BBQ the other day, but was in a hurry to get back to class so I didn't stop... Call me when you are ready to put that bed back on and i'll come up!!
Jay, thanks for the offer, but I have 3 teenagers coming over Saturday Morning to help. Should be a 5 minute job.
Marshall, I will search for a number on the carb as soon as I start diassembling the other side of the engine bay, which should be tonight.
I have an original starter & solenoid on its merry way from Southern California, along with a new Clutch Master and some suspension goodies.
Discovered that new boots for the Knuckles don't exist, so the plan is to patch up the old ones like you would a bike tire. On the boot that has a rip rather than a hole, I plan on using a suture kit to first stitch it up, then apply the patch. (Slime makes a nice 56 piece patch kit). I figure if those patches can hold 110 psi, they can hold back grease at very little pressure. We will see.
There is a guy in Mint Hill, NC, who is the national guru on Coronas (the car, not the beer), which share the 3R engine (1.9 liters of fun) and I am buying some bling for the engine from him (read here decals).
