- Thread starter
- #121
@Comet
Thanks for the tip. I have a new mechanical fuel pump here and hopefully a fuel filter.
Thanks for the help. I did check the fusible links and clean the contacts at the same time that I cleaned most of the other contacts a few weeks ago...I don’t know much about 40s, so sorry if this is an ignorant question. Are there any fusible links in the ignition wiring? If there is one, I wonder if you could jump around it and see what happens.
I hate chasing electrical issues, so I feel your pain. Hope you’re able to figure it out.
That's some good stuff right there! I'll give that a go tomorrow too. It'll give me a chance to replace my cracked clamshell with the non-cracked one thats been on my shelf.Worth consideration .... test to find out if there is a dead spot in the ignition switch.
Pull off the clamshell and (carefully) run an alligator clip jumper from the +12V solder joint to the "run" solder joint. Then see if it starts.
you mean these keys ................
Yup those same ones. I still need to install the driver side lock gasket. Passenger side is all in.
Did you try jumping power and ground to blower directly? I am not even going to ask if you checked the solder joints in the control box......sorry, I had to.I replaced the carb cooling fan fuse. It hard the original Pacific red 5 amp fuse burnt out. I removed the cooling fan switch control box and cleaned out the dust, debris and contacts. I checked continuity at the thermosister and have good continuity through the wire to the housing. I am guessing the relay may be bad.
I didn't test the fan yet but it's easy enough to do. I figured I'd check the fuse 1st. I did check all of the solders on the control switch circuit board and they were all good. I sprayed some Kroil on the thermsister hardware and will take it off to clean it up in a few days after a few heat cycles and applications of Kroil. Meanwhile I'll go through my junkyard toyota relay box and see if I can find a match to the relay.Did you try jumping power and ground to blower directly? I am not even going to ask if you checked the solder joints in the control box......sorry, I had to.
