For Sale New Jersey, Toyota Land Cruiser BJ70 1990 ~~~
$ 16,000 !
This is an imported car from Costa Rica. the VIN number is
BJ700001071
Engine Specifications
177 miles (285 kilometers)
Model: 3B-II
displacement: 3431 cc
injection: indirect
horsepower: 90, 93 or 98 at 3500 RPM torque: 159, 163, or 167 ftlbs at 2200 rpm valves: 8 ohv
bore: 102 mm
stroke: 105 mm
compression ratio: 20:1
compression pressure:
normal: 30.0 kg/cm2 (427 psi) or more minimum: 20.0 kg/cm2 (284 psi) difference: 2.0 kg/cm2 (28 psi) or less
Differentials
Most BJ series Cruisers have a 9.5" ring gear, and the differentials are offset to the right.
axle code: K052 differential type: open ring gear: 9.25 inch
ring to pinion ratio: 3.70:1
Transmission
type: 5 speed manual code: H55F
gear ratios (to 1):
1st: 4.843 2nd: 2.619 3rd: 1.516 4th: 1.000 5th: 0.845 rev: 4.843
Yes Power Steering
24V batteries
Yes Heater
no AC but I have one new in the box if you want to install
NO rust! this car is well taken care of
Includes all these Add Ons!!!
Roll bar 6 points: inti 600$
high mask bumper : inti 550$
Back bumper rally :inti 450$
New stop light Toyota original
New door mirror Toyota original
New grill Toyota original
2 new batteries
New old man emu suspension $1800
New dipped headlights Toyota original
New plastic carpet original Toyota
tires are 35 inches with Toyota original rim
stainless steel muffler 1300$
New clutch 700$
Located at Clifton, NJ.
Call or text 646-361-6738
~~~ $ 16,000 ~~~~
How many miles?
12v or 24v?
Power steering?
AC?
Heater?
Rust?
Where was it imported from?
Lockers?
How many miles?
12v or 24v?
Power steering?
AC?
Heater?
Rust?
Lockers?
177k miles or 285 kilometers.
24V
YES power steering
No AC but I have one new in the box that can be installed.
Yes Heater
Imported from Costa Rica
NO rust! None at all
no lockers
Hello, wish was FRP top, by any chance you sell the A/C system, also do you have any more parts (snorkel, running boards, brush guards, etc, btw take trades on this one?
Thanks
I remember this vehicle from 2017. I was interested in it, the OP listed at $10K and was relativity stock for the most part. Paint looks decent.
