I got my 100, Natasha, about 2 years ago now. She's a '99 and came with a 2" OME lift, stock rear locker, and a broken CV joint. Since then, we've had our ups and downs: she's had her fair share of issues. But I think we've got things working now. We are in AZ, and like getting out quite a bit. I've been a member for a little while because I was looking for some technical help a while back. I'll list some of the problems/solutions below (The Saga).
Problem: Broken CV
Solution: Replace both CVs and install Slee diff drop.
Problem: Crunched rear bumper, and bent lower control arm (from extracting the car) in Utah
Solution: Custom bumper built by my brother, and installed used control arm.
Problem: Engine immobilzer wouldn't turn off.
Solution: (After many dead ends) New master key, and new immobilizer antenna.
Problem: Crunched rocker panels from sliding on snowy shelf road.
Solution: (Recent) Custom sliders built by my brother.
Problem: Leaky rear axle seal.
Solution: Replace rear axle seal (x2 after doing incorrectly the first time).
Problem: Worn lower ball joints.
Solution: Pressed in new ball joints.
Problem: Ventilation fan stopped working (an issue during AZ summers)
Solution: (After much time spent diagnosing) Replace fan relay.
Problem: Engine immobilizer malfunction (again!!)
Solution: Replace fuse box. The fuses were not blowing, but melting. Also, replaced sending unit on gas tank because that had crapped out too.
Problem: Bent exhaust pipe after getting stuck
Solution: New section of exhaust pipe, and routing it differently to (hopefully) avoid that again.
Problem: Complete brake failure, warning lights, and warning noise
Solution: (After much time spent diagnosing) Replaced entire brake pump/master cylinder assembly. The solenoids on the assembly stopped working. Replaced one brake relay. This was pricey.
Problem: Truck pulling oddly while turning driving up hill. I was convinced it was something with the steering, but figured out it was the differential disintegrating after it blew up. This makes perfect sense in retrospect.
Solution: Gears and an ARB locker from Just Differentials.
Problem: All front axle and drive shaft seals leak after I had the ARB installed.
Solution: New front axle seals.
Problem: Bent lower control arm after sticking it on a rock. (Same one as before)
Solution: Yet another used control arm (still waiting for it to arrive).
Modifications/Upgrades during repair:
2" OME Lift
Slee Diff Drop
ARB front bumper
10,000 lb. Superwinch
ANZO lights
Stock Rear Locker
ARB Front Locker- wired into stock 80 series switch and dash light (I'll make a post about this wiring)
Constant Duty ViAir compressor with 2.5 gallon tank
Custom Sliders
Custom Rear Bumper (I'll make a post about this build).
Current Status:
Problem: Broken CV
People ask how I managed this, as the road appears flat. It wasn't flat, but I'm still not sure how I managed this one. The rear end slid over instead of going over the rock.
Whoops!
Bending the exhaust pipe. Whoops!
2" OME Lift
Slee Diff Drop
ARB front bumper
ANZO lights
Stock Rear Locker
Custom Sliders
Current Status:
At Chiva Falls near Tucson, AZ
Getting through "The Squeeze" on the Sutherland Trail near Tucson, AZ.
