My O-ring does not look so good![]()
Well when I separated the 2 halves, the ring stayed on one side but it "seemed" to be a larger diameter than the groove (stretched I guess you would say). I let the 2 pieces lean against one another while I worked on the LC in my blazing hot garage (I call it the steam room) and just before I came in I laid the one half down and worked it back into the groove. It now stays in the groove for now. I hope this does not pose a problem.
WTF's up your ass?
Alright, Shannon. I'll remain on topic at all times from now on.
That promise will last for about a minute!![]()
I'm not an official CSC member anyway, so I guess I can break the club rules.
So what is the life span on the "gooey stuff"? I have a friend with a '60 that is asking me. Seems he is interested after I did mine.
Damn it man!Further review shows that the above draining method is only good for the Aisin clutch. The Eaton has an anti drain back provision, the pump out port comes to the center of the reservoir, so draining that way will be slow and likely to leave some old fluid in the clutch. The best method would be to prop the valve open and lay it flat.
Anyone with an Eaton who didn't notice as big of a difference as hoped, this is likely the reason. I'm open to redoing them.![]()
