Well finally got the replacement diff fitted in my front axle yesterday - got fed up with the noise in the end. A whole catalogue of woes was found while it was out but luckily the new diff is good and the noise has gone.
Diagnosis of the noise, Pinion was worn as was the crown wheel, was only running on the edge of the crownwheel and that was worn really rough. Lot of play in the pinion bearing.
Also both front drive plates are badly worn, changed one Birfield, got to do the other one and change both drive plates relatively quickly.
Wheel bearings were loose (hadn't checked them since last August - naughty), splines were shot on the old Birfield that was replaced as well as the Birf itself being knackered.
However one good thing, both swivels are good and the seals weren't leaking so the oil under the front of the car is all from my leaking power steering pump - next thing to change.
The Cruiser runs a lot quieter now, still got a slight hum but I think this is the wheel bearings which I will be changing, think them being too loose has probably not done them any favours although they didn't look bad. Hum now happens on acceleration as well as deceleration which was not the case from the front diff noise which only happened on acceleration.
