My window switch assembly was in pretty rough shape and one of the switches wasnt working. I bought a new one from switch doctor. It was $88. It only comes in brown. The description says you can easily swap the outside trim from your old one. I got the switch in about 2 days. It is very high quality with the same connectors and colors on the wires.
You cant swap the trim, as the switches are built in. At least I couldn't. I had to swap one wire in the harness to match my old one, so compare the wires closely. I ended up painting mine and it turned out pretty good. I used a small sponge brush to remove the paint from chrome letters right after i painted it.
Good purchase, but needs some work to make it right.
I guess it is possible to take apart a switch and clean the contacts, but my switches and trim were rough looking.
Toyota Land Cruiser Window Switch 1984-1988
