Pathfinder
I am the STIG
Big thanks! Got my tracking number today and looking forward to installing!!
I have an 87 fj60 with a 2f and I'm thinking I need a carb as the HC readings are off the charts during my latest CA smog test. Have you had anyone use one of your carbs on a smogged rig? The only things I'd be missing are the hac and the decel fuel cut right? I could still run my air injection and egr with this unit no? Thanks!
Marshall,
This is one of your carbs - there is about a 3mm gap between it and the air cleaner housing. FJ40Jim mentioned in another thread that you might have a spacer to address this issue. Is that something I can buy locally or something I should get from you? I realize it is not aligned perfectly, but I think I can move the bolts to the valve cover to line everything up pretty easily.
Let me know what you think. Note: the OEM gasket is sitting on top of the carb.
Thanks,
Greg
Marshall,
Thanks,
Greg
Sorry it took me so long to get back to you. I believe my carb has a mechanical throttle linkage. What are the prices and how do I reserve one of the new batch. Thanks again.What carb do you have now? Do you have a cable or mechanical throttle linkage?
