New F & 2F carbs
Does this unit have a fuel return?
No but if you get me on a good day I will drill and tap it for a small of 65. I hate doing them. They really aren't needed for my carb.
Any Carbs available?
Just Paypal'd for the FJ60 carb...when do you think you can get it shipped out Sir?
Ned new carb. 1980. Fj40
Hello
Ant carbs available
My Aisan took a dump
Thanks
Eaj71
I am having a problem installing. I am going from a weber carb which sucks donkey balls and converting to a trollhole carb on my 78 FJ55.
I think I am missing a spacer and the one I have the threads are to close both directions for the new TH carb to go on.
can anyone tell me what I am missing or will need?
The spacer you have on there was designed for the weber carb. What you need is the carb insulator that has a built in spacer with gasket seals. You can contact SOR for a new one that is revised. $118.00
Also if im not mistaken, there are 2 spacers on there for the weber. Carefully remove the gasket layer and there should be a allen screw holding down each spacer. I just removed mine sat :)
Crap. You also need the stud bolt kit and nuts. For the trolhole carb. Also you will need air cleaner box to accomodate the factory type carb. Specter Offroad heped me a lot when i was there last week collecting parts for the trolhole carb. Just waiting for my new carb delivery.
so to confirm beyond what I have already sourced:
carb insulator
4 studs
4 bolts
carb base gasket
