New F & 2F carbs
67 as in the two bolts holding the carb to the manifold 67? If so this will not bolt on to a 67 that I know of. But I'm willing to figure something out so it will.
How about a picture of what you have?
Hi Marshall,
I wonder if you've figured out a solution for these earlier F's. I tried searching through the 39 pages on this thread but probably didn't search well enough. I have an early '65 build with the original SD40 Aisin big window carb and have been having problems here:
https://forum.ih8mud.com/40-55-series-tech/780684-sd40-big-window-carb-leaking.html
and here:
https://forum.ih8mud.com/40-55-series-tech/782104-aisan-sd40-carb-question.html
After enough tinkering, I think it's time to experience the ecstasy that is the Trollhole Carb. I just need to know which one would work with the mechanical linkage and bold to the intake.
Fingers are crossed, hoping it's possible.
I can get more pics if you need next week when I'm back in town.
Any update on this batch of carbs/dizzys? Late October has come and gone...
Opened the hood and found my relatively new trollhole carb broken. See pic. Any thoughts on how to repair?
Looks like the bolt came out. Can you confirm it's not broken off inside the casting?
If it's just missing I'll send you a new one.
Hi Marshall,
and here:
No adapter for the early carbs. While a buddy of mine installed a Weber adapter and got it to work. It didn't work as well as I thought it ought to.
trollhole I have a 1963 FJ40, it has a single barrel oem carb, that bolts to the manifold with 2 bolts. It has a mechanical throttle linkage. Does your carb work for this system?
Thanks
Snowtoy
Thanks
Snowtoy
I'm sorry it doesn't. Have you called Mark at Marks Offroad or Jim C at TLC performance? They can rebuild your single barrel for you.
