New F & 2F carbs (50 Viewers)
Payment sent for FJ60 version. Any update on the timetable?
Also, Thank you for your excellent work, sir.
No not yet. It's at least 4 weeks out.
SO how's this carb working. It looks like you've sold a few by now. I have a 76' Fj40. I am removing the smog EQ. Stock Dist. does this perform better that the stock carb? HP increase ammount ? Milage increase?
Yes you could say I've sold a few. out of a thousand I've had 18 with issues.
It is just as good as a new stock carb. So no it doesn't perform better than a stock carb. Just as well. No HP increase unless your old stock carb is dirty or in bad health. Then yes my new carb will increase your hp. Millage is the same as HP. Your not really going to get any better. Maybe a little better but not much over a correctly working new stock carb.
Unbolt your other one and bolt this in it's place. Then remove and plug any smog stuff.
As far as the dizzy if it's an vac advanced electronic. I'd keep it. If it's a vac advanced points it's a tossup on the condition of your distributor.
I want to know if you still sell the carbs and dizzys. Do you have pics of the dizzy?
Alvaro
I'm new at this. I need info. I've a 2F 1984 FJ40. NON cable type carb. Need vacuum advance dizzy and car. (Is carb like original?)
Paid today via paypal. I got the $290 carb/cable set up for my 70' fj40 with F motor. I'm looking forward to it!
Alvaro
I'm out of both right now expecting carbs in a few weeks.
How can I contact you>
https://forum.ih8mud.com/trollholes-cruisers/597873-how-get-touch-me.html
Carb is similar to what you have if yours is stock. Will bolt right up.
I don't have any type of smog system. Will the carb work on that?
Yes
Hi. I live at 7000 and so does the Goose an '85 FJ60, desmogged.
Most of my driving will be at this altitude and higher.
Got high alititude jets?
Thanks.
The last carb you list, the one for $290 that accepts the throttle cable from '70-73, will it accept a later style air cleaner assembly that mounts with a stud?
Trollhole carbs are great. I have using it for some time, and Marshall is great at support. Had an issue last spring and he was good for it. I even bought a spare for backup, but sold it.
dougbert
