Ok, it's been several days since I discovered a serious problem with my newly installed 3FE and have finally calmed down enough to ask the question before I assume the worst and pull everything apart again.
I just put this replacement 3FE in my truck about 4 weeks ago. It seems to be running fine (bonus) but the clutch will not disengage (I just get grinding gears). If I start the truck in 4th, it just jumps forward until I let go of the ignition switch. I've checked the MC/slave circuit and everything looks good there. I bled the system and am seeing plenty of slave piston/release arm throw as well. Next, I pulled the inspection cover and had a helper depress the clutch pedal. I can see the pressure plate flexing and the disc, sandwiched between the flywheel and pressure plate, seems to be relaxing (spreading) as the pedal is pressed. I'm going to take some photos/video shortly to illustrate what I'm talking about. Looking up there with a flash light, it does like of look like the pressure plate fingers aren't "arched" quite like they should be... but that could just be my imagination.
I am 100% positive that when I assembled the clutch to the flywheel (over a month ago) that I pulled up ih8mud mobile on my phone and reviewed archived topics to confirm the disc orientation before I put it together. What I'm not so sure of is if I may have removed the disc as I had to lift the engine a bit more to get the pressure plate under the bellhousing (because of the way I had it sitting on my shop floor). The only thing I can think of is I may have pulled the disc out before I lifted the engine a bit higher and may have oriented the disc incorrectly when I put it back in. At the time, I was more concerned about the TO bearing orientation, which I also confirmed via ih8mud mobile...
What I'd like to know is if there is anyway I can visually check for a backwards disc BEFORE I pull the engine and transmission back out. I imagine, the only thing worse than installing the disc backwards is pulling everything back out just to find that it wasn't backwards to begin with. I'm out of ideas though as to why it will not disengage.
Thanks, Gents.
Thanks, Gents.
