Pick up from partsouQ a Toyota oem canister
P/N 77704-60290.
Fit is good and can be made perfect if you grind off this back plastic part around the canister. I decided to just cut the top strap off and use the bottom strap only on the bracket. Another easy issue is the purge feed off the canister is the next size smaller, so I just stepped the original line down a size with what I could find in the garage. Letter this week I will just replace all the old lines and clean it up. Part was 228.00 shipped from Dubai and took 3 days to get.
P/N 77704-60290.
