Is it possible to connect this brake master cylinder wiring into my old wiring harness and back to my red brake warning light?
It's an 11/71 the wiring is fine, I'm pretty sure the original connectors fell off though. And I can't seem to find any diagram that shows the correct color. I have 2 loose blue/red wires but the diagram shows green/white, which makes sense because the parking brake and brake light on the dash is green/white. And my original master cylinder only used 1 wire but this new one uses the black and white. Should I ground one?Simple answer is yes. How you do it will depend on if you are willing to cut into old wiring or want to use connectors and wire to bridge the systems. What year are you dealing with and is the wiring still intact?
I was just going to snip the connector and put on these factory style bullet connectors I have a bunch of...This may have the information that you are looking for.
T100 Non-ABS fluid sensor plug
So, when converting to disc brakes a lot of us use the T100 non-ABS master cylinder. We are then tasked with finding a plug to connect to the sensor that is in the side or out of the cap. Because the car runs without one connected a lot of us simply do without the function of the brake warning...forum.ih8mud.com
