Looking for anyone that has a CB or scanner with NOAA weather band function. Hoping to get either that will fit as a single DIN unit below an aftermarket single DIN head unit. Maybe a handheld CB unit? Searched around on the internet a bit. Pics? Basically I want a CB, scanner, and weather radio. Trying to get two in one. Thanks.
You're not going to find any unit that combines a CB transmitter, scanner and a weatherband receive capability.
You can get a CB transmitter with weatherband radio.
You can get a scanner that will receive weatherband and receive CB, but it won't transmit on CB.
Most CBs won't fit a single DIN or the ashtray location. If you find a writeup here (there are several such threads IIRC), then use the radio specified or you may find that it won't fit.
Some scanners, including the top end Uniden mobile trunking scanners, can be installed in a single DIN mount location. I haven't done that in our 80, but installed one in a Tuffy console's single DIN location. I suspect that this would also work in the dash in an 80 in concert with a single DIN audio head unit in the other slot. YMMV
