Correct, I had dashboard speakers x2 with rear door speakers & a cargo area "sub" (6.5?).
There are plugs in my front doors for speakers...
Hopefully they're hot!
I recently replaced the headunit and speakers in my 1992. It didn't have door speakers to begin with and it only had 4" speakers in the rear. I also looked at the Pioneer head unit, but it didn't have a knob to manually adjust volume. I would find that very annoying
This is pasted from my build thread
https://forum.ih8mud.com/threads/build-thread-for-the-german-shepherd.805447/
"Head unit and Speakers
After dealing with the poor sound quality and lack of features on the headunit for years, I got a Kenwood DDX470 headunit and four Kicker KS65 series speakers.
http://www.crutchfield.com/S-UntIXwXcUS5/p_206KS65/Kicker-KS65.html
I had previously installed a Kicker shallow mount sub http://www.crutchfield.com/S-yEQ9cEsEp9f/p_206CVT651/Kicker-10CVT651.html
in the third row so I figured I would stay with Kicker, and I liked the look of the speaker grills.
The front doors did not have speakers in them to begin with, and the rear doors had 4" speakers.
I wanted to keep all the speakers looking the same and use the grills, so we made plates to mount the speakers away from the dash.
Then we measured where the hole would be and cut the door panel.
To keep the speakers from hitting the window when it is lowered, we had to use plastic spacers on each side. View attachment 895356
Then we plugged them in to the existing speaker wires and screwed them in.
For the rear speakers, we used the same Kicker KS65 speakers. We had to enlarge the hole because the rear doors originally had 4" speakers.
Old vs New
We also had to use 1" spacers in the rear door to space them away from hitting the window when it is lowered. View attachment 895364
There was a pretty noticeable improvement in sound, but the biggest improvement came from the new head unit."
With your powerful welding medicine!Appreciate the link, too, with your USB ports and such I'm subscribing to that thread for reference.
So you abandoned the factory mounting holes mainly due to clearance/speaker thickness?
EDIT: Almost forgot to ask - were you able to use the factory wires/harness to power those speakers, or did you run new?
The rear speaker mounting holes were for 4" speakers and the Kickers were 6.5s. They had to be cut out and enlarged so the factory mounting holes were gone. The front speakers were completely relocated so the speakers wouldn't hit the dash. The 1" spacers spaced them out from the window tracks and solved clearance issues. The wires are all factory, but on the front, we had to lengthen them to reach over to the new speaker mounting location.
