I have a BJ74V-MNX Toyota LC Prado. It has a 13B-T in it. Everything was working fine except that it did 4km/lit and had problem with brakes.
It was a beast, had tremendous power yet produced black smoke with full throttle. To lower the fuel costs and emission, I asked a tech to fine tune the pump. He did so yielding performance drop (notably). I asked him to undo the changes (as I prefer power), he messed with it but no increase was seen. He told me that 'pump plungers' along with some other things need to be changed, did so but still nothing.
Now coming to brakes... While crusing I noticed that brakes used to get pumped and thus didn’t used to work properly. Asked a mech to fix it, he said generator needs to be replaced. Result: Brakes are ok (not good as they were) but the clutch, it gives me quit a work out. It is pretty 'hard'.
Asked the mech to fix it, he said there is nothing much he can do. Why? well...... He cannot.
I took the matter in my own hands now, so here is what I did and need to know:
a) I think the mech messed with vacuum and air tubes/pipes. This resulted in performance drop (according to me). Need to know what tubing comes from turbo and enters the pump. I need the tubing diagram or someone who knows 13B-T well, he/hers help via this forum.
b) I think the generator the mech installed is not really for this Prado. How I know? Here is what I did:
I swapped the clutch and brake tubing. The result was clutch operated smooth (as it should) but the brake got 'hard'.
If you look at the back of the generator, you would find a small cup that has three tubes coming out. One for brake, one for clutch and one for engine shutdown. The engine cut off tubing is shared with one of these two (clutch, or brake) tubing. Clutch and brake tubing are larger in size.
This cup has an impeller that produces air. If the shared one is used for clutch; clutch goes hard, if used for brakes; brakes go hard and engine takes time to shut down.
I removed the cup and noticed that the 'shared' pipe outlet had a considerably small hole than the non-shared outlet. My question thus is, Should I just increase the size of this hole? Perhaps that solves the problem? Does anyone know the size of these holes?
c) I have a CT 26 turbo in it. It produces only 5psi and the green light turns on 2000 rpm. A week earlier, it produced 10psi, what happened?
d)Lot's more still to come
....First help me with the above problems.
I can provide pics if you do not understand what I am saying. Just do reply (it would encourage me).
