Hello everyone!
I’m jumping in on what is obviously a very old topic in general for FJ 40s, but this is something specific enough that I need some real tech advice from the best people on the Internet and that’s the folks on ih8mud!
What I have is a 1977FJ 40, I got the power steering conversion kit from Cruiser Outfitters, and a Toyota 4runner power steering box (1981-1985, 4wd). The conversion kit, of course, comes with a pump, mounting bracket and the high-pressure hose.
So, here follows the tale of probable idiocy, seeing as I don’t necessarily know my way around power steering. Got everything installed, read through the Toyota 4-runner manuals to find out which was the high-pressure and low pressure ports on the gearbox, (I think I got it right). If anybody can confirm the one that I believe was the high-pressure line is the one that’s on the inside lower port. I could post pictures when I get to a computer if that would help.
In any case, got it all installed and did the old-school form of bleed, which was probably a bad idea. That’s where of course you turn the wheel back-and-forth with a vehicle jacked up about 20 times and then turn it on and then do the bleed again with a vehicle running while turning the wheel back-and-forthand then put it all back together. In the next go around of course I’ll do a vacuum bleed just to make sure.
The whole thing worked brilliantly for about two days. At one point, though when I came home, I made a hard right turn on the steering wheel to the stops as I was prepping to park and suddenly I could not turn the vehicle left without great effort. I figured that that was probably a bleed problem and I’d overheated the thing and had air in the system because I didn’t do a great job at that bleed I guess (or something else). So when testing it today I checked tye fluid, did another bleed, and in the middle of the bleed process, the high pressure line actually burst at the crimp. So now I know I either had a really bad high-pressure line or I really screwed this thing up.
I could use some advice!
