need help troubleshooting FJ 40/mini truck power steering upgrade
Laguna Hills, CA
Hello everyone!
I’m jumping in on what is obviously a very old topic in general for FJ 40s, but this is something specific enough that I need some real tech advice from the best people on the Internet and that’s the folks on ih8mud!
What I have is a 1977FJ 40, I got the power steering conversion kit from Cruiser Outfitters, and a Toyota 4runner power steering box (1981-1985, 4wd). The conversion kit, of course, comes with a pump, mounting bracket and the high-pressure hose.
So, here follows the tale of probable idiocy, seeing as I don’t necessarily know my way around power steering. Got everything installed, read through the Toyota 4-runner manuals to find out which was the high-pressure and low pressure ports on the gearbox, (I think I got it right). If anybody can confirm the one that I believe was the high-pressure line is the one that’s on the inside lower port. I could post pictures when I get to a computer if that would help.
In any case, got it all installed and did the old-school form of bleed, which was probably a bad idea. That’s where of course you turn the wheel back-and-forth with a vehicle jacked up about 20 times and then turn it on and then do the bleed again with a vehicle running while turning the wheel back-and-forthand then put it all back together. In the next go around of course I’ll do a vacuum bleed just to make sure.
The whole thing worked brilliantly for about two days. At one point, though when I came home, I made a hard right turn on the steering wheel to the stops as I was prepping to park and suddenly I could not turn the vehicle left without great effort. I figured that that was probably a bleed problem and I’d overheated the thing and had air in the system because I didn’t do a great job at that bleed I guess (or something else). So when testing it today I checked tye fluid, did another bleed, and in the middle of the bleed process, the high pressure line actually burst at the crimp. So now I know I either had a really bad high-pressure line or I really screwed this thing up.
I could use some advice!
I thought the ports were different sizes so you couldn’t mix them up?
As for bleeding, the way you did it is perfectly fine. There’s no reason to need to vacuum bleed power steering, I’m not even sure how you would.
I’d be suspecting a bad pump or box since it locked up one way. Maybe the pressure relief valve was installed incorrectly (or not at all?).
Your method of bleeding the system was fine. If you did have air in the system, the pump would whine and you would have aerated oil.
IDK if that year box has the same size ports or not. My 86 and 88 box have different size inlet and return ports. I'd think if you had them reversed, it wouldn't have worked well for two days but, maybe not?
The pump relief should handle a pressure spike. It limits pressure when you hit the steering stops. Holding it against the stop isn't good because of the strain and heat generated but it shouldn't blow a hose.
If it was mine, I would verify for sure which port is which. If it is correct, and the gearbox is NOT binding up both directions with the wheels off the ground, I would try another hose. I would also check pressure to ensure the pump relief is functioning properly. Hopefully it was just a bad hose.
If the steering box did feel crunchy or binds up when tested, I'd be looking at the box before I went further. There may be debris in the system at this point. So even if you get another box, flush it out and check the pump.
on this pump, both of the ports seem to be the same size. Your point about the pressure relief valve is very interesting. The pump is from JTOutfitters & the gearbox is from an overseas merchant and it’s not necessarily the same kind of 4-runner four-wheel-drive power steering gearbox that most people use for their conversions. As such it did not cost that much and perhaps there’s something defective with it. I think it’s best not to underestimate that and I’ll go ahead and purchase a domestically refurbished gearbox that is the model most people use. Definitely better to be safe than sorry! I should probably decide if I should consider a different pump!
there is no sense of grinding, as I was turning the wheel back-and-forth with the wheels off the ground yesterday, and it was going both directions, but whatever happened to make it so that I had to attempt to re-bleed when it did power assist to the right and not to the left a couple nights ago has me concerned, certainly. After only a day and a half of use, I can say that the power steering fluid smelled a little burnt to me which has me also concerned. I think that could be due to excessive heat from air in the system, but maybe also something else.
If you look at the pic that shows your blown hose, you can see it looks like the flare nuts may be the same size, but the hose metal ends are different. The high pressure line side looks slightly smaller. So, if it were in the low side, the nut might thread but you’d have a sloppy hose fit. Also, the low shouldn’t fit into the high side because the hole would be too small.
Again, I don’t think you had a bleeding problem. Power steering systems are relatively simple in that aspect and they don’t “unbleed” unless you ran it low on fluid and it sucked air. As said, you can hear it when they have air or not enough fluid in them.
Maybe this older thread is helpful. As others have said, bleeding the system is simple. I'm sure some others have just added fluid and ran with it and let it bleed itself.
The relief is typically built in the outlet fitting or sometimes looks like a plug in the pump case. That's "usually" the source of heat in a PS system. The fluid should have constant flow BELOW relief pressure until you steer against a stop or high load. If something is making it go over the relief for more than a few seconds, it will sure burn your fluid.
I hope you get it figured out. I'm curious to see if it can be hooked up backwards. Easy to do if both ports are the same size and not labeled.
Maybe this is where I need to be looking. I may put in a new pump just in case. I an not sure of how the relief works, unless it is just out of the cap. There are a number of holes in the pump case that leak if not plugged by a bolt: One in the back and a couple of mounting bolts hole options in the front. I need to understand these more I think. (I believe the relief file was all internal, but I am throwing off a little bit by the fact that the pump casing leaks if all the holes are not plugged with bolts, lol
I recently rebuilt a saginaw/scout box. I dont think a p/s box would offer any power assistance if the lines were reversed. Once the Fluid has gone thru the high pressure side/valve it's work is done and fills the low pressure side of the box.
thank you everybody so much for all your help. Well it’s hard to tell exactly what happened in regards to whether or not I had a pressure problem due to a bad pump (which I’m starting to think might be the case) or a bad hose, I’m going to go ahead and start over with a new pump from a local reputable shop and a new gearbox just in case, also from a local reputable shop. The one day where I had what felt like good power steering was an amazing moment and I cannot wait to get back to it in my 40 you guys have been a really great help, thank you so much!!
Okay, here’s a backup question: I’m at the end of a complete replacement and reinstall: Pump, gearbox, cooler and hoses. Mindful that the JT Outfitters conversion hose that connects the Saginaw pump to the Toyota box blew after only a day of use last time, I am realizing today that the HARDEST part of this project by far has been to get the JT high-pressure hose in. The fittings are facing such directions that no matter how I arrange the hose, I have to twist and bend the hose quite a lot to get it to fit. I think that this torsion may have led to the blowing of the hose at the gearbox side crimp. Tore right off! (Not super twisted, but definitely a good deal rotation to get the end to the gearbox). i can’t for the life of me explain how else the hose exploded like that.
Assuming that heavy twisting of a HP hose is a bad idea, I’m wondering if anyone has a suggestion on how I might just get a regular Toyota pick up truck HP hose and find some kind of adapter for the Saginaw pump end? Or maybe I should be looking for a male to female flare end extension that I can bend to mate better with the JT conversion hose. I’m not familiar enough with flare fittings and pipe ends and all that to find the right kind of adapter and I could use somebody’s help.
According to the JT outfitter site, the fittings are 5/8 18 on the Saginaw end and 10mm x 1.0 on the Toyota end.
A little twist to get things tight and not leak is normal/acceptable IMHO. You can walk by and look at it and notice its twisted, then that's too much. Hoses/fittings fail on occasion - even when new. Spend some time and look at fittings - they make about everything but you will need to likely order from a online place - pay attention to shipping prices. A local hydraulics shop might be able to help you out.
PSC might have what you need to adapt or even make your own hoses. I bought the correct JIC/AN adapters for my steering box and pump and made my own hoses. Once you have the adapter for your pump and steering box, you can either buy a hose that is the proper length or easily make your own.
Summit Racing and even Amazon might have the PSC parts you need for less. Just search the part number of the adapter you need. Good luck with your project!
There are shops that will make up custom hydraulic hoses. I use Diesel Parts of the Carolinas in Wilmington for PS, AC, etc. hoses. They have most fittings and can weld yours to a hose with a strait bit of tubing. Check your local area for one of these shops.
You guys are all brilliant, I totally forgot that I have a crimping tool in my garage that I bought specifically for AC hoses and they would do just fine for this too, I’m pretty sure. If worse comes to worse, I could probably just get a chevy hose and a Toyota hose and simply cut them in half and couple them together as long as the hose is the same diameter
