Need help sourcing front engine mount bolts for 1969 fj40
Helena, MT
Here's a pic of the placeholder bolts I have in the mounts. They are too long, though I think the right threads per inch and diameter. I've been searching on the interwebs to find 2 mounting bolts for my front square SOR engine mounts. It's a 1969 fj40 and I can't seem to find the bolts. I can find lots of pictures of mounts and lots of other bolt kits, but not the 2 bolts for the front engine mounts. Does anyone have an idea where I can find these?
View attachment 2821570View attachment 2821569
You might try calling Mark at Mark's Off Road. 65swb45
If he doesn't have them, he will point you in the right direction. My other thought is McMaster-Carr.
If you know the size you need, Belmetric will have them. Due to shipping, I suggest ordering any other fasteners you need as well.
Those also look like the bellhousing to mount bolts. The front chassis to mount are a finer pitch thread and different head.
@Honeycutt
The OEM bolt for the OEM front motor mounts, as illustrated, has the part no. 91619-41228.
Note that the "square" style of motor mounts were specified for 1975+ applications, but luckily may be adapted to early Land Cruiser model years.
They list for $2.96 each at your local dealer, and include a captured lock washer.
You guys are awesome! Thank all for your suggestions. I think I will order from my local Toyota shop, might as well get some missing bell housing to transmission bolts while I'm at it! @firemanj92 you were right I'm sure, I just found those laying around and figured out the thread width was off, so didn't tighten them, just used them as placeholders. @73FJ40 totally appreciate your level of detail and information. Right on! Thanks y'all! You're the best!
I found out the hard way and had to retap a front motor mount-bolts were in wrong baggy. I'll find the tap size...M12 x 1 for front but I don't remember the bellhousing m12 x ?
yours in the PHOTO Are CORSE thread
you NEED Fine thread
simple solution
all you need is :
12mm thread pitch x 1.25 x 28mm long ..............
MUST BE #8 JIS Spec for motor mounts .....fyi
