Hi guys,
Today I started to take apart the rear end of my 1982 Hilux LN46 4x4, to replace the wheel bearings and fit an Aussie Locker.
The left drum came off easily, but I am having problems removing the right drum.
I have:
1 - Backed off the adjustment as far as it will go, so the shoes are not dragging the drum.
2 - Rotated the drum backwards a few turns, I was told this might help?
3 - Hit the drum hard with a hammer/mallet etc. on the shoulder area.
4 - Used a pry bar between the drum and backing plate.
5 - Sprayed solvent degreaser everywhere I possibly could, and loads of it, then tried 3 and 4 again.
I read somewhere that the drums are meant to have two threaded holes for bolts to go into, to push the drum off. However my drums have 6 plain holes (no threads).
What should I do next?
I have:
) this would be, but if the above doesn't work, is there enough surface exposed beyond the backing plate that you could get some purchase on the drum with a bottle jack inserted sideways?
