landtank said:While this might help you better manage the wandering and such it doesn't address the underlying problem which is that your caster is way out of wack. You might seriously look into the drop brackets that MAF is now offering to work with those arms to get everything back in alignment.
Though it does point out that making sure the rest of the suspension / steering is in good shape before lifting is important as any short comings will be amplified.
At 7.5-8", if you correct enough for caster, I'm guessing the pinion angle is going to suck, and you're going to start cutting and turning axles.
