Mystery Sunroof Weatherstrip Location Found
Winter Park, CO.
When I closed my sunroof one day, I had a piece of weatherstripping fall into my lap. I posted a question to see if anyone knew where it came from. Where does this part go?
After some investigation, I located it's home and returned it there. It belongs on the rearward metal plate in the sunroof opening. The sunroof presses against it when it drops into the lower postition to slide open. My guess is to keep it from rattling? I couldn't tell any other purpose for it.
The strip:
The strip partially installed:
The strip installed from the bottom(kind of hard to see, you might have to zoom):
The strip installed from the top:
While looking into this I also noticed that the rear part of the weatherstrip on the sunroof glass itself is catching on the roof of the truck when it's closed from tilted up postion. It took some work to bend it back in place, but even then I had to lower it a bit at a time to make sure it didn't bind on the roof again. The roof looks like it's aligned properly so I'm not sure where to start with this one. I'd love some input if anyone has seen this before.
Bent glass weatherstrip:
It was actually bent up in two places. I had bent one back in place before taking this pic.
Reason #471 I love this site. I had that exact thing happen - that piece landed on the center console. I looked... looked... watched for leaks. Nothing. So, I stuffed it in the bin with other random 'Cruiser stuff. Now, it'll return home.
Thanks!
Bumping this thread because I just reinstalled mine after it being in the seat back pouch for the past decade. It fell out a long time ago and I could not find out where it belonged. Thanks!!!
What is the p/n for this piece? I think mine is missing.
Might be shoved back in the headliner. Pretty sure that's where mine is.
Mine keeps coming off. I’ll look for a solution when it finally warms up...
I still don't have a solution for keeping it in place. Maybe I just didn't push it to it's recess enough...
I quickly tried setting it and noticed it didn’t seem snug. I haven’t spent too much time yet, but I might get some weatherstrip adhesive to help tack it in place.
