Keep in mind, as OAT drops so does coolant level.
Only bad leaks leave a puddle. But one of the nice things about Toyota "red" or "pink". They leave behind a colorful dry crusty at any leak. In searching, make sure to check ever inch of head gasket along with both front and rear weep holes. Don't forget to inspect heater cores as well.
Old radiator cap along with sticky thermostat, may result in loss at overflow of reservoir. In this case; level usually stops dropping as reservoir nears the low line, unless engine is really overheating.
Overnight pressure test of coolant system can revealing.
