- Joined
- Sep 26, 2003
- Threads
- 117
- Messages
- 11,200
- Location
- Lancaster, Ohio, USA
- Website
- www.tlcperformance.com
If the 77 2F can be had reasonably, use it.
Use the 71 clutch, flywheel, release fork, pivotball, hydraulics.
If the 71 hydraulics are shot (probably), then use new 77 master & slave, bend a new hardline as needed, re-use 71 slave pushrod if needed.
77 BH & 4spd.
71 BH engine mounts for slave mounting and t-case shift linkage.
4spd-3pd t-case adapter gear, bearing, etc from @65swb45.
71 t-case for the lower low range and vacuum shift.
To make the swap easy, use the 71 manifolds, carb, air cleaner, exhaust sytem, etc. Also, it will guarantee that the brake MC and carb don't have interference.
77 points vac advance dissy.
The steering is good enough as-is, just grease the ends, refill SBX w/ gear oil, adjust slop out of center arm.
Brakes will need work. Rebuilding wheel cylinders is iffy, and new ones are expensive, so it might be worthwhile to go ahead and do a disc front knuckle upgrade right off the bat.
My work here is done. Get busy!
77 BH & 4spd.
