- Thread starter
- #21
I came across that. I may give it a try.If it will run long enough, you can use a block tester kit that can be rented from an auto parts store. they are not invasive and don’t lie.
Aren’t 25&26 EGR and O2 sensor related?
Has it gotten much colder than normal lately? My money is on a loose clamping ring on one of your hoses and it puked coolant. Common when it gets cold as coolant expands.
I think your rough running is unrelated to the coolant loss.
This is based on my minimal expertise.
i would bet one of the coolant hoses or the phh is leaking and the rough running is related to something else. My phh would puke randomly with almost no signs until i figured it out. Plus it could be any of the front our rear heater hoses. Even with a bad hg it would run unless a ton of coolant got in the cylinder and hydro locked it but if that happened you would have a bent rod or worse. plus the 93 and 94 are not as prone to hg failure as the 95 and older are. pull the plugs.
Is that enough brown milk? Just went out and looked.Is there a brownish milky sludge either on the underside of your oil filler cap or on your oil dipstick? Dead giveaway to a blown head gasket...from experience.
Welcome to the addictionI just picked up this 94 LC about 2 weeks ago. Straight trade for my 05 Pathfinder. This makes my 30th vehicle owned and I have to say one of my favorites. I have driven a few over the years including a rhd one in Afghanistan and have had owning one on my list.
It has 230k mile, a few modifications, and overall is very clean. It came from Colorado originally, so it is rust free.
My plans are to fix everything that is needed including,RH mirror, antenna, rear hatch lifts, and front axle seals. Also needs tires so I am going to 33s and maybe a small lift. Trying to keep from going crazy since I have other projects that came first. We’ll see how this goes.
Earlier the dipstick just looked very clean. I will check it in the morning.From my perspective - YES. As suggested, you could drain the oil and see if it has that same look and runny consistency. I certainly wouldn't drive it very far! Same junk on the dipstick??
I just repaired code 26 on my 94, turned out to be a bad pair of O2 sensors. Here are a few links that may help you trouble shoot your codes.
How i fixed my 94 L.C. check engine light Code 26
http://www.risingsun4x4club.org/uploads/Snowrun/1994 fzj80/1994 Repair manual/Service bulletin/T-CP-SO2-0162-W.pdf
Vf1 voltage
Checked the dip stick. Looks normal. I am still going to do the block test. As long as that comes back normal I will move on to others.
I did notice when I was digging around looking for vacuum leaks that the exhaust is leaking at the manifold/downpipe and right before the cat. Could explain the codes?
